SOLD 1987 D250
niceolddart
S.E. Pa.
Reducing the price on this truck to $2500! Was asking $2700. (See pics. under 1987 Dodge D250) May be moving & it will be one less thing to move. I removed all side moldings, pressure washed it, replaced dimmer switch (was sticking), front side marker lights, installed 2 new Halogen headlights, all headlight adjusters & 2 new wiper blades. Needs turn signal cancel switch replaced, doesn't self cancel on left turns but works. as does EVERYTHING else. I am patching the drivers floor near heal/throttle pedal area, (minor hole) adjusting driver door so it closes & seals better. Starts right up & runs good, etc. Should go right through Pa. inspection once I fix the floor. I will post more pictures of the progress I've made. I really must sell this or my 95 Dakota, but would rather keep the Dakota. Make me a reasonable offer.
I will NOT be moving now so, I took rubber matting from floor to repair rust holes, (worse than I thought) Removed all exterior trim (heavy!) to check for more rust & to power wash exterior. It is surely worth fixing it so I am repairing the floor on drivers side, passenger side is good but will coat both sides with POR15 when new floor pan is installed. Repairing seat belt attachment area & proper seat belt, installing complete new ACC rubber floor mat & new turn signal switch too. Truck is too solid of a truck to not fix right. I will probably have it Inspected also while I have it, so the price is going back up. I will be asking $3000 for it now.
wouldnt mind a truck like that...... 3 pedals even... something I can't find any more.
I still have it & need to get rid of it. I thought I had it sold, I was wrong. $2000 takes it. Should be ready to pass Pa inspection.
