1970 Dodge D 300 Brake Rebuild
Nathan
Minnesota
Hello All,
Doing brake rebuild on front axle on my 1970 Dodge D 300 dually.
Where the brake line goes thru the frame there is this bolt/ nut adapter where it transitions from rubber to steel.
Where do I source this part or do I bypass and not use it. I don’t need the repair to be correct, only functional.
Thank You, Nathan
Hello All,
Thank You, Nathan
Have you checked Rock-Auto? They have items listed for other vehicles that are easily cross-referenced that might help you out.
Try and think outside the box when searching which vehicles might be suitable.
For example, I couldn't buy a fuel tank to filler tube rubber hose (about a foot long) to suit my Australian 2006 Falcon. So, I searched through the listings of similar aged Mustangs, and I found an almost perfect match - only had to trim about an inch off one end.
Without the Rock-Auto search function I would have needed to deal with endless numbskulls at Parts Stores and probably never get an answer.
Yes I have looked at rock auto and parts geek.
Also tried NAPA and Oreillys.
Not a lot of info .
