Some Mopar things I have seen lately
65 sporty
Kingston, Mi
I have had a few interesting Mopars recently. First one was a long time customers 1988 B250 custom van, it needed a water pump. So while I was in there I decided to pull the timing cover also because of the fear of the gasket being disturbed from pulling the water pump. I put a timing set in while I was in there also. Here is the set I removed, still in decent shape for being original
We had a 73 Charger with a 318 in the shop, this one jumped time, this is the gear we found upon tear down. Very typical for the age of the gear set.
I had a 12 Grand caravan in with a 3.6, it had over 300,000 miles on it and it needed spark plugs. Upon removal of the plugs I found these.
3 plugs had to have been original, these were the worst plugs I have ever seen. The other 3 had been changed at some point, those could be changed without removing the upper intake manifold. I have no idea how those plugs were firing being so worn
Wear and tear, and they still keep running...... not Mopar, but my Toyota van needed a water pump chage a few years ago - at around 250,000km
What we found when removing the pump was almost beyond belief.....
That tells me the cooling was been managed solely on convection rather than flow. I often sit with the engine running and the A/C on full cold.....and the engine never gets very hot. The 4-cyl 3.0 litre diesel is a pretty solid engine. I have had it 19 years now and it has been a reliable work horse for me. At 28 years old, it is still going strong.
What we found when removing the pump was almost beyond belief.....View attachment 26933View attachment 26934
My 5.9 diesel has a hard time to come up to temp.....I can block the radiator 85% and it will run at 180 in 70* weather but will get up to 195 in extended stops like in heavy traffic. And don't tell me to install a new stat. Done that many times and gave up and went to the blocked radiator. The down side is that the AC doesn't like a blocked condenser when running it on a sunny 70* day in slow traffic.
That is ugly, looks like the coolant may have started to become acidic
I had this 2012 town & country come in, it had some starter noise and a slight vibration at idle. I found this
Usually they make a lot more noise
