Finally installed
lou3500
Redneck Garage
Palm Harbor Fla.
I finally got my LED light bar installations done today [i have had these since October] i bought from E Bay- 2 ea. 6 inch led's to serve as reverse lights and a 44/46 inch light bar and a 52 inch roof mount and custom brackets to mount it [only 2 people make them for 94-01 rams] and i got the cheaper ones which i had to re bend to work properly for how i wanted them to mount [their way was half assed] IMO, i'm happy with the install overall [my 44/46 is gonna be moved but for now it's OK] lights work great. I have no idea why i bought these damn things i don't off road or nothing i believe it was to further the look that i'm trying to achieve [no idea what to call that look it's just an idea in my head]!!!
Nice Lou ! I was thinking of installing them on my next 4x4 build . Have you tried them at night yet ? I was wondering if you got much of a reflection off the hood because of where you mounted them above the windshield ?
Yeah I say that makes a little difference ! lol Thanks ! Hopefully I'll be starting my next 4x4 project next spring and lights like that will definitely come in handy .
E Bay if you catch them you can get a deal my [under bumper] 44/46 [as the seller called it] was 38$ shipped and 13$ for the wiring kit [switch harness relay].
Yes i do i had to do a headlight modification on my 66 Cuda because they were like two candles at night and they pulsed i rewired them using relays directly from the alternator and they are bright now with no pulse!!! What is the vehicle your having issues with that ram pickup?? That's a newer truck late 80s /early 90s ain't it should be bright.
Up grade to HID's they make kits for just about everything.
My car I was referring to is a 97 Maxima I got for $250. I haven't put a dime into it in the year I've had it. I'd bolt those lights right to the hood!
I replaced the point type voltage regulator with an electronic one and rewired the headlights with relays direct to the alternator thru a fuse. No more pulse and brighter [used halogen bulbs].
I installed my new headlights/turn signal assembly's today and relocated my lower LED light bar [moved it further out].
