Transmission whine is gone!!
Paserdener TX
Now we'll see if the trans will last. It ran fine with the wheels in the air. Sure was cruddy in there too.....
Fluid and filter. Didn't adjust the low/reverse band tho. Wanted to see if it was going to act like it did before. I'll be changing it again soon along with a new filter and will adjust the L/R band. The inside of the trans looks pretty nasty. After dropping the pan I knew I had been in it before but I'm sure it was 15 years ago and most likely used Dexron II.
Yeah , run it for a little bit and then do another service and I think you'll be fine . Good job !
The filter must have been plugged, did you pull a cooler line and run it to drain the converter?
Hey Cranky,
I know it's an older thread, I'm late to the party...LOL
I didn't catch the orig. thread or problems either...
Anyway, how many miles before it started showing signs of issues ?
just curious
is it the 44re ?
