Where was the ballast resistor mounted?
nothingbutdarts
Bailey, Co.
I just bought an 1984 W150 with a 318. It had electrical issues and the previous owner has done a hack job on the wiring. I just got it running but the ignition syst. is laying all over the place. I found where the ignition box bolts to the firewall under the master cylinder, but can't find where the ballast resistor would bolt to the firewall.
Any help guys would be appreciated, Thank You!
Look to your right and up a little from your ignition box . You should see the hole for the screw that go's thru the middle of your ballast resistor . It take's the four prong style .
