LocuMob
Fluid Technician
What trans is behind a 318 in a 97 Ram 1500 2wd extended cab short box? Just want to know if it's the same as my 98 Ram 2500 4x4 before I get it.
So, other than OD, the internals are the same, 2wd and 4wd? The trans would be the main reason to get the truck, if it's different I probably wouldn't bother.46, 47 or 48 RE 96 to 01. The 97 318 more than likely has the 46RE.
Have read there is a difference in overdrive placement between two and four wheel drive vehicle's.
