2003 Ram with 100,000+ miles. My right turn signal and brake light stopped working on my trailer and truck camper. First checked the wiring going to the trailer and camper, no apparent problems. Then I checked the fuse/relay box to see if there was a blown fuse. Well there are a ton of fuses and relays in there, and the main truck lighting has fuses and relays which are replaceable.
Turns out that the trailer lights are on a different circuit, and the relay is built into the fuse box itself and is not replaceable. $500+ to replace the fuse / relay box just for the part alone. The part is specific to the VIN number of the vehicle so finding the right one in a bone yard would be a crap shoot.
I ended up tapping into the trucks brake light circuit and jumping a wire over to the trailer wiring harness. Ghetto rigged, but it works and saved me from spending $500 on a relatively old truck. I figured that since the trucks main lighting circuit is fuse protected the since the relay iseasily replaceable that this was my best option.
