resto
Hey guys. Well I have a 1976 F100 long bed with a '78 400/c6. It cranked right up after I purchased it but I never let it warm up bc it needed a radiator. I replaced radiator and it cranked right up, but I then noticed coolant leaking from the heads right at head gaskets, and what I thought was oil pan but that turned out to be freeze plugs. I changed the Head gaskets and all other gaskets associated with job, and after wouldn't start. I have timed it, replaced starter solenoid, ignition coil, ignition coil connector, Ignition control module, complete dist with cap and rotor, spark plugs, and I am still forgetting something. I have ruled out a fuel problem. Now I NEVER buy blind parts, but these parts were beat up and going to get replaced anyway, so I went ahead and did them with this no start problem. I have checked the wiring over and over again. I do not understand why it started every time without issue, and now I can't get it to fire up. It has to be something I did wrong...but I took very detailed pictures before the Head gaskets and labeled all the wires and bolts very carefully. A little OCD. Does anyone have any ideas on how to figure out what is going on... Should I look towards my automatic choke? Pouring gasoline in the carb still doesn't get a start though. Ugh it is killing me.
Thanks-Jeremy
Thanks-Jeremy
