Last
74 D100 with a 318 and 727. When I hit 100 mph the trans felt like it went into neutral and the engine almost over revved on me. I let off the gas real quick but got on it again after dropping down to 90 and the trans acted normal and wanted to pull again. The engine nearly over revved from that so I dont feel like I want to try it again. Is there a speed limiter on the trans at 100? Or is it something worse. I have no problems shifting. My TV is set correctly. I had no burning smell or smoke. I might have a bit too much fluid in the transmission. My trans stick tube is bent funny (the wrong way due to a header install.. rookie mistake) so I cant check the level until I get another dipstick tube and bend it correctly for header clearance.
