No od was working
The overdrive on the 93 two wheel drive auto will not engage. The dash switch is no and no check engine light.
This started Monday only other symptom is the engine dies while braking with trans in gear. Converter is releasing but not sure about lockup.
Item that will be checked soon. Speed senser and overdrive solenoid wireing.
Any thoughts out there?
Fluid level is ok. We drove over a tree limb a pulled wires loss on the tail shaft. Pluged it back in today. Will find out tomorrow if it solves the problem. 4 wire plug been looking for the wiring diagram to verify what the wires feed but believe they are for the converter and od.
Everything is working again. Still have no idea what the fourth wire is four or why they do not know where the connector is on the case.
