Dodge truck rear axles
Kern Dog
Granite Bay CA
I'm a bit curious about the rear axles used in Dodge trucks from say....1970 until the early 90s.
Out here in California, I've owned several of these as well as being a junkyard crawler for years. It has been my experience that the 9 1/4" rear axle has been the most common unit used in the 1/2 ton and light duty 3/4 ton trucks.
The 3/4 tons with the higher GVWR stepped up to the Dana 60.
The 8 1/4" axle was also used though some refer to it as the 8 3/8" unit. I'll refer to it as the 8 1/4" for now.
It is my understanding that the 8 1/4" axle was used in 1/2 ton models only and not with any 400 or 440 powered trucks.
I've never seen an 8 1/4" axle in any 4 wheel drive truck. I've never seen one in any Ramcharger or Trail Duster.
I admit that I have not seen everything but some people at FABO seem to think that the 8 1/4" axle did come in 4wds, 440 powered trucks and 3/4 ton trucks, three things that I have never found in the many trucks I've seen over the years.
The 8 1/4" axle was a medium duty unit. MY own '70 Charger came with an 8 1/4" axle since the car was built with a 318. 383 2 barrel cars also got the 8 1/4" axle as standard equipment but the 383 4 barrel cars automatically got upgraded to the 8 3/4" so it would sure seem like if Ma Mopar didn't trust the 8 1/4" to a 3700 lb car with a 383 4 barrel, no way would they put this axle in a 3/4 ton truck.
5.9 equipped Durangos had the 9 1/4" unit and they are not 3/4 ton trucks.
What are your opinions on this?
The 8 3/8 (that's how Mpoar reefers to them in vans and pickups) was used with 400 trucks, 4WD and both combined. Ramcharghers got them too, 2WD and 4WD. And there was a version that was used in 3/4 and 1 ton vans in the 80's.
I've beat the living hell out of them with no issues ever.
60 years of owning, driving, wrenching on Mopars of all makes/models and I've never heard of an 8 3/8 rear differential. But then, considering all the other typo errors in your post, I guess what you really meant was an 8 3/4" rear?
There are references to an 8 3/8" axle in the factory service manuals. They are the same as the 8 1/4" axle but for some reason, they called them 8 3/8" in the trucks.
I've still never seen one of them behind a 440.
Thanks for the clarification KD. When I had older Dodge trucks ('49, '53 '65, '72, & '87) I never had the service manuals for them so never heard about the so called 8 3/8" rear. Actually come to think of it, I do have a service manual for my '53 Dodge. I'll have to check out the section on the rear to see what it says.
My apologies to CC for doubting his post.
It is an 8 3/8. That IS NOT a typo!!!! There are NO OTHER errors in my first post either.
OK, it must be me then. But can you please clarify what a "Mpoar reefers" is/means??
Also I'm wondering what a "Ramcharghers" might be??????????
Both are from your first post. But, whatever, you are correct about the 8 3/8", verified by KD. Thanks so much for the info.
Maybe the dude was posting from a phone and didn't look his post over before submitting?
I make the majority of my errors when doing that. Tiny screen, tiny buttons and 59 year old eyes! When I go back and see my spelling errors, I immediately correct them.
I agree with you, I think that is probably the case with his post. (Either that, or too much sauce while posting??)
BUT, my whole point was that I thought he meant an 8 3/4 instead of the 8 3/8 that he posted. I thought his 8 3/8's statement was a typo based on the fact there are several other typo's in his post. (Which he then denied that there were any??)
I apologized to him once already, I won't do it twice. All done with this topic now. 👋
