To much or to little resistance or a mechanical problem with the vent valve itself. Could check the mechanical portion of the EVAP vent valve and see if there is a problem.
Check the wiring at the connector and follow it back some, common problem I see with P0449 on GM trucks is a bad wire at the valve or within a foot of it.
