Aussie Challenger
I am looking into fitting the 46RH trans into my '79 LRE, trying to keep it as close to original as possible, leaving it an auto. Should be a fairly straight forward fit up except it is a little longer.
When searching the net there appears to be many different modifications that can be done to this transmission but I suspect that most are not needed unless you intend to go racing.
The trans can be upgraded to 47RH (Diesel) specs like clutches but apart from that what is really necessary?
Trans-go have a kit, TFOD-HD2 which is supposed to be a very good upgrade, Sonnax also have a kit, SC-46/47RHE, do either of these kits have much in common except for the manual selector valve supplying oil in Park? Which is the better, I am leaning towards the Sonnax kit?
Living down under we don't have ready access to these transmissions like you North American cousins so little is known about them. I am looking to finding a transmission needing rebuilding and upgrading and have shipped across the water to me. Transmissions already reco'd are very expensive and from over here any warranty work if needed would be on me anyway.
PATC have a kit for using pressure switches and vac. switch connected to trans port which turns the trans into a fully operational auto for the O/D and Lock Up, beats flicking switches on and off.
I have read a couple of articles of these trans being fitted to sedans without many problems so fitting to my LRE should be reasonable seems as the trans was designed for Pick-ups and Vans.
Has anyone had anything to do with them or can comment on them?
David
Aussie Challenger
David
Aussie Challenger
