'81-'93 Dodge glove box lock replacement
85crewcabbie
Tucson, AZ
Silly little thing but can't find anything in the factory shop manual. Nor do I seem to be able to figure it out. When I remove the retaining screws the lock assembly is loose but the exterior bezel won't pull through the hole in the door. It seems like the exterior bezel has to be removed first. Before I muck it up trying to remove the exterior bezel I was hoping to hear from others who may have had to make this repair and have done so successfully.
Never done it myself but there is a cylinder release on the right side of the lock in the box. If yours is a keyed lock you will need the key to get it out.
