sam un ont
I have a 08 silverada that has the right rear brake caliper sticking .
So far I have replaced the rotor, caliper and flex line with no success.
When it starts to stick the brake pedal will get slightly higher and eventually the right rear will get hot.At this time I get underneath and release the bleed screw (only a light dribble comes out) and all fine until the next time. Iwould mention also that when this happens I can pry the pads back with little effort
Since there is only one line going to the rear my thinking is that if the problem is in the abs module or master cylinder both wheels should be affected
Any help is appreciated
Sam
Sam
