PlumCrazy4Mopar
Awhile back I posted that this truck was posting a code 23. I have not figured out this issue except to know there is not unit in the hole on the throttle body. Nor is there a wiring connector in that vicinity. I have a temporary tag on the truck with an appointment for inspection on Monday. While test driving the truck it sounds like something has a failing bearing. Sounds like an irate cricket on the passenger side of the engine while driving the truck. The next issue is when you park and turn the truck off it does not want to restart for several minutes. After a good warm up while driving it hesitates like the accelerator pump is bad. As it has a throttle body I know that is not the issue. Also when you hard accelerate it bogs down.
Any suggestions would be appreciated. Thank you!
