Kern Dog
I'm a bit curious about the rear axles used in Dodge trucks from say....1970 until the early 90s.
Out here in California, I've owned several of these as well as being a junkyard crawler for years. It has been my experience that the 9 1/4" rear axle has been the most common unit used in the 1/2 ton and light duty 3/4 ton trucks.
The 3/4 tons with the higher GVWR stepped up to the Dana 60.
The 8 1/4" axle was also used though some refer to it as the 8 3/8" unit. I'll refer to it as the 8 1/4" for now.
It is my understanding that the 8 1/4" axle was used in 1/2 ton models only and not with any 400 or 440 powered trucks.
I've never seen an 8 1/4" axle in any 4 wheel drive truck. I've never seen one in any Ramcharger or Trail Duster.
I admit that I have not seen everything but some people at FABO seem to think that the 8 1/4" axle did come in 4wds, 440 powered trucks and 3/4 ton trucks, three things that I have never found in the many trucks I've seen over the years.
The 8 1/4" axle was a medium duty unit. MY own '70 Charger came with an 8 1/4" axle since the car was built with a 318. 383 2 barrel cars also got the 8 1/4" axle as standard equipment but the 383 4 barrel cars automatically got upgraded to the 8 3/4" so it would sure seem like if Ma Mopar didn't trust the 8 1/4" to a 3700 lb car with a 383 4 barrel, no way would they put this axle in a 3/4 ton truck.
5.9 equipped Durangos had the 9 1/4" unit and they are not 3/4 ton trucks.
What are your opinions on this?
