JGC403
I am swapping a 383 with a 833OD into my 1985 Ram. I have the correct motor brackets, (I got them from here: http://www.bpeusa.com/BPEtruckKit.asp ). Installed the engine and trans into the truck last weekend. I was waiting on a new transmission mount so the trans was just sitting on a 2x4 on the trans X-member. Went to install the mount today and the holes are about a half inch off between the bracket and the holes in the tailshaft.
So I'm trying to figure out whats going on. Looked up part numbers for the transmission mount and they are all the same part # doesn't matter if its big block or small block, auto or manual. I'm pretty sure that the distance between mounting holes for the transmission mount and where the trans bolts to the back of the block is the same length between autos and manuals with the long tailshafts. So I'm stumped.
