5.9 magnum engine, trans, and transfer case swap
Fixitmg
Eagle River Alaska
I see a bunch of people have swapped in a magnum motor in to the older dodges, But has anyone done the complete swap with the trans and transfer case.
I can't seem to find anyone who has. I would like to make this a daily driver, with the smoother shifts and overdrive feature.
I have a complete wrecked truck and should have everything i might need as far as electronics to make it work.
Be prepared to change the front axle also as the front drive shaft may no longer be on the passenger side.
If you have a complete doner truck and the mechanical ability I don't see a problem.
