have a 86 dodge 318 truck has a bad tranny but thinking in swapping SB to a 440, is this possible !? is this truck equipped with a computer that would make this swap impossible !? any guidance would be appreciated !?
Big Block trans tunnel ? Huh ?Yes it's possible! And there isn't much in the way of getting it done other than engine mounts and exhaust, radiator/heater hoses. You'll need a big block trans tunnel also. But it can be done fairly easily.
I meant trans case. I had just woken up. Tunnel might be a bit of an undertaking!Big Block trans tunnel ? Huh ?
Forgot about the pan. I have them laying all over from all the RV 440's I've picked up, I'm usually looking to put a truck engine in a car.For starters you'll need the mounts & brackets , small brake booster , exhaust ( either truck manifolds or headers ), oil pan & dip stick , big block transmission , and you'll also need the correct power steering pump bracket . That's just off of the top of my head .
That will be a fun one!It's a 4X2 bear .. But I won't have issues with computer, I think there's one next to da battery
If there's a computer behind the battery then more then likely it's injected . But there's way's around that . Just means a little more wiring . Personally , I'd get rid of it entirely .It's a 4X2 bear .. But I won't have issues with computer, I think there's one next to da battery
Go ahead , rub it in Mob . I'll have you know that Luci's running nice and cool "now" .I think that's about it for the basics, there really isn't that much you need to do it. It might also be helpful to get a larger radiator, right bear? Lol
Well it's just that there's no real bolt in tube that clears the headers whether you run it off of the stock pan or the block . I run the stock 7 quart pan and dip stick and I still had to tweak it to clear the header tube's . One of these days , I still have to fab up a bracket to bolt it too . Right now it's just kind of chill'in between the head tubes and it kind of bounce's around when I'm at idle . It's on my to-do list with everything else . lolTruck rb headers that much different from car header that the dipstick tube is a problem?
