Ghostrider 67
So, I need to replace the bottom rear bed side behind the wheel well where the black and silver 4" molding runs. Once you remove the molding the white plastic clips slide sideways and then down, off of the little metal studs. The problem is the repair area includes the little bitty studs. So, once the new metal is welded on, how do I reinstall the 4" trim clips?
I'm sure it's something simple. Thanks.
PS. While i'm at it, what's the secret to removing the 3/4" wide polished trim at the top that goes all the way around the body?
