shangche001
Primary maintenance
is generally carried out when the car travels to 1500-2000km, mainly tightening and lubrication.
Check the tire appearance, tire pressure and inflate.
Check that the engine and chassis should be free of grease and mud after wiping.
Check and add lubricating oil to the engine oil pan, transmission, rear axle, and steering gear to make the lubricating oil surface to the standard part.
Check electrical systems, such as generators, starters and various instruments, whether they are working properly; check whether the liquid level of the battery and the casing are leaking, whether the air holes are unobstructed, etc.
Eliminate the faults and defects found in the inspection.
Secondary maintenance
is mainly for inspection and adjustment. The secondary maintenance is a more in-depth technical inspection and adjustment of the vehicle driving a certain mileage
Carry out all the contents of the first level maintenance
Check and adjust the brakes and perform tire rotation
three-level maintenance
Cleaning, inspection, adjustment and elimination of hidden dangers are the main tasks.
The work content includes: dismantling and inspecting the engine, checking the cylinder, piston, piston ring and tie rod, bearing wear, removing coke deposits, glue and cooling system scale, grinding the valve and adjusting the gap
If necessary, inspect the frame and body, remove rust, touch up paint, etc.
Pickup is a good helper for us to get rich, it silently sticks to its responsibilities. It can not only meet our daily car needs, but also take the lead at critical moments. It comes and goes 365 days in the wind and rain. This is not without hard work. In order to keep the pickup truck in its best condition and give full play to its maximum role, we cannot ignore the daily maintenance of the pickup truck while enjoying the benefits of the pickup truck. However, do you know that the maintenance methods for pickup trucks of different ages are different? Today I will tell you how to do it.
The first two years are the golden age of pickup trucks, which is equivalent to our youth, just like the sun at 8 or 9 in the morning, never getting tired. At this time, the condition of the car can be kept in the best condition, and routine maintenance can be carried out, basically there will be no problems. At this time, the maintenance strategy is also very simple, only need to replace some of the most wearable parts.
After two to four years of use, the car has begun to enter middle age and is no longer as full of vitality as it was in the early days. At this time, we should begin to pay attention to vehicle maintenance. In addition to routine maintenance, we should frequently replace some parts to supplement energy.
Cars with a history of more than four years are prone to problems, just like human beings enter the "menopause". It is inevitable for them to lose their temper. At this time, many parts of the car began to age, oil and water leaked from time to time, and small problems began to appear one after another. This needs to be dealt with in a timely manner by the car owner. However, this is also a good time to sell a car. If your car was well maintained before, you can definitely sell it for a good price.
Six to ten years is the "old age" of pickup trucks. If the car is overused and poorly maintained, there will be "general strikes" three or sixty-nine, "small strikes" embarrassing situation every day. At this time, car owners will often worry about various unexpected situations, because all the things that can be broken have been broken once, and the only ones that are not broken are those parts that have been replaced. At this time, while strengthening vehicle maintenance and regularly replacing vulnerable parts, we also need to check the condition of the vehicle at the maintenance station or maintenance center from time to time. Routine inspections and maintenance work must be carried out before and after driving, so that old cars can retire safely.
Generally speaking, the daily maintenance items of dfsk pickup trucks include: oil, transmission oil, oil filter, air filter, fuel filter, air conditioning filter, spark plug, brake fluid, engine timing belt, engine coolant , Power steering fluid, brakes, batteries, tires, etc. However, when to replace it is determined by automobile production technology, accessory technology, driving habits and usage conditions. As for the maintenance frequency, generally speaking, it is 5000 kilometers/3 months, 7500 kilometers/6 months and 15000 kilometers/12 months.
