shangche001
Many friends have different understandings of car maintenance. Now the three-point training and seven-point training are also deeply rooted in the minds of car owners, and car maintenance is extremely important in cars.
Many friends say that it is easier to buy a car and it is difficult to maintain a car. Novice drivers don’t even know the price of owning a car. So how much do you know about the cost of owning a car? Some car maintenance knowledge requires in-depth understanding. Next, let us introduce the maintenance cost of a car in detail, hoping to help you.
We can use the engine oil recommended by the manufacturer, especially when selecting gasoline grades. At the same time, choose a big brand gas station to refuel, so as not to add low-quality oil.
know that vehicle maintenance is very important.
Car maintenance: first maintenance
Maintenance items include: oil, oil filter;
The general maintenance price is around 200-700 yuan. This first maintenance project is very simple, depending on the brand of engine oil to choose to use. If it is a small-brand product, it is about 200 yuan. If it is a recognized Mobil oil, about 700 yuan!
Car Maintenance: Second Guarantee
Maintenance items include: oil, oil filter, air filter
The maintenance price is around 350-850 yuan, the same as above, mainly depends on the brand of the replacement oil, whether it is a synthetic oil or a semi-synthetic oil!
Car maintenance: general maintenance
Maintenance items include: engine oil, oil filter, air filter, air conditioning filter
The maintenance price is generally 470~930 yuan, the same as above, mainly depends on the brand of engine oil to buy!
It is difficult to generalize the specific price of a car maintenance, how much is the maintenance cost of a 4S shop.
After all, the price of maintenance items in each 4S shop will be somewhat different. At the same time, the price of vehicle maintenance is closely related to the level and difficulty of vehicle maintenance.
If the store must be maintained, it also has its own standards.
For ordinary people’s cheap cars, the car ranges from tens of thousands to hundreds of thousands, and there are also millions of vehicle maintenance programs that are also very different. A small maintenance of a cheap car costs two to three hundred yuan, depending on your vehicle. The most expensive items are about one thousand to three thousand yuan.
If an ordinary vehicle is undergoing major maintenance and replacing various filter elements, it may be 600-1000 yuan cheaper and 6000-8000 yuan expensive, depending on the maintenance content of the vehicle, such as engine injectors, air intake system, three-way catalyst Even the inspection and maintenance of the upper and lower parts of the vehicle, oil replacement, and the cleaning of automobile air conditioners are carried out together. This service is diversified, and of course the price also rises. The expensive maintenance costs of vehicles The consumption even reached more than 10,000 yuan.
The small maintenance cycle of the car is generally 5000 kilometers, the medium maintenance cycle is 20,000 kilometers, and the large maintenance cycle is 50,000 kilometers.
Generally, if you find a faulty light on the dashboard while driving, you should go to the 4S shop to check the vehicle as soon as possible.
Car maintenance items usually include the replacement of four filters (air filter, oil filter, gasoline filter and air-conditioning filter) and the replacement of five types of oil (brake oil, transmission oil, engine oil, direction Oil and differential oil).
At the same time, check whether the three types of water (coolant, glass water, antifreeze) are adequately used. When maintaining a vehicle like dfsk, you must also ask the 4S shop to raise the vehicle and check the chassis structure of the vehicle. Maintenance is better than repair. Timely maintenance of the vehicle also extends the life of the vehicle in use.
