hello i'm new to the truck forum but have been on a body for some time now my problem is there some where I can find a brake diagram for my 1999 ram 1500 . I changed our my front calipers and master cylinder and I cant get the front brakes bleed out only rear are working and pedal is low the combination valve keeps flipping over and I remove it and push the piston back and the light will go out until I try to bleed it and it flips back blocking off fluid to the front. I have loosen the lines and let it gravy bleed over night . as soon as It get 1 pump it flips over I went to the dealer for a new combination valve and its discontinued if they found one its 400$. any info or magic wand would be helpful . I been a mechanic for 45 years and never had a simple problem like brakes make me pull my hair out and its always on my own truck THANKS this truck appears to have rear abs only is this possible?
