TrailBeast
TrailBeast posted a new classified:
Advance Modded OEM Distributors for small blocks
Read more about the classified...
OEM small block remanufactured distributor with FBO timing plate and Mr. Gasket 2,500 RPM "All in" spring kit already installed and ready to drop in.
Install this distributor at 14-16 degrees initial advance and you will end up with an approximate 32-34 degrees all in at about 2,500 RPM's right out of the box.
Mechanical advance is adjustable from locked out (zero mechanical advance) to over 50 degrees just by changing the advance plate position and/or initial timing.
Also comes with...
