    Dismiss Notice
Ac changes from cold on drivers side hot on its own
Discussion in 'General GM Truck Discussions' started by Challengingjab, Sep 8, 2015.
  1. Challengingjab
    ChallengingjabMember
    Aug 7, 2015
    FL
    I have a 2004 Silverado that the ac on the drivers side will change on its own to heat while going down the road . Passenger still on ac . The only way I can get it to change back to ac is to shut off ignition and restart 20150807_172809.jpg truck then it changes back on its own . Anyone know why or the fix for this problem?
  2. augie didesidero
    augie didesideroNew Member
    Aug 16, 2015
    I don't know the answer , but my 02 olds was doing that while still in the 3 year warranty , the dealer worked on it all day back then , and fixed it. then while working on it last year , I didn't plug in a vacuum line and the whole ac / hv system went wacky , ac coming out the heat vents on the floor ect. the system used vacuum to switch the vents from floor , defrost , ac ect.
  3. 65 sporty
    65 sportyWell-Known Member
    1,179
    535
    Aug 8, 2015
    Marlette, Mi
    If you didn't get it fixed start with the blend door motor, one for each side.
