robsw200
Hello,
I recently rebuilt a 727, dont know if it was working before it all came together with the truck. I put everything together and road tested it, 1st gear and reverse work fine but it will not shift up at all. Took it up to almost 40mph and it was screaming but no upshift. I adjusted the throttle linkage and its fine. I tested the governor port with the wheels up in D going about 10-15 mph and there is no pressure at all. My line pressure im not able to read accurately since my gauge only goes up to 80psi but it was pegged out at idle in D with the wheels up. Im guessing there might be something stuck in the governor assembly, but before i tear off the tail housing in this 100* heat could it be something else?
