The Mopar Dude
Go ahead, take the day off
1987 Dodge W150 short wide bed 4x4, 318 2bbl, 727 automatic, power steering, power brakes, air conditioning, tilt wheel. Silver/gray with a red interior. Superwinch front hub lock-outs, factory steel spoke wheels, 30x9.50 mud-grip tires. New windshield and wiper blades, new calipers and pads on the front, transmission serviced and shift shaft seal replaced, new valve cover gaskets, new water pump, radiator replaced, new battery, completely de-smogged, new electronic ignition, cap/rotor/wires and plugs. New pivot bushings in wiper system. Steering coupler replaced. Everything works (lights, signals, windows, gauges, tailgate, hood release, shift indicator, etc) but a/c needs charged. Steering is tight and drives/stops very nice. Minor outer sheet metal rust but floors, cab, fenders and hood solid. Very nice dash and door panels, rubber floor mat shows no wear. Heat and defrost ducts work correctly. Starts, runs, drives, charges and shifts correctly. Runs cool and has no major leaks. Grille, headlight doors and front bumper very nice. 4wheel drive system works correctly and has front lock-outs to save wear on front drive system as well as increase fuel mileage. Tires are LOUD and nearly new but back ones suck.
Would make a good daily driver, project or back-up vehicle. Can be driven as-is and would only need tires in the future. Very hard and expensive to find a short bed 4x4 that has the mechanical integrity this one has. Has a little body rust but isn't ate up like they usually are.
Truck is in Burlington KS 66839. Clean clear title. 620-364-8200.
$4950
$4950
