82 Ramcharger with 93 5.9, D60 upgrades
chickendeluxe
440magnum
My 82 RC is lightly modded 318, small Cam, Sniper system, 33x12.5 with stock gears now…..body work done…. Want to make it kinda trail, light tow reliable
Got 93 w250 5.9 magnum, 46RE, D60’s 410 parts truck.
Besides electronics, is the trans, adaptor, 205 case, front driveshaft a bolt in from Longbed w250 into Ramcharger?
Will start with Axles since I’m like a 294 D44 and 9.25 now and trucks a pig. Will front Dana driveshaft bolt up to existing 82 318 2bbl stock 241 case?
Thanks for the help….. still new to truck swaps
Trans and all should bolt in, driveshaft should work if you are using one from the '93 parts truck.
The driveshafts both front and rear will have to be different length then you stock shafts. The 46RE is longer than the stock trans because of the OD unit and will push the transfer case back further.
