    Dismiss Notice
2000 Dodge Dakota power outlet
Discussion in 'Dodge Dakota' started by oldguy, Jul 10, 2018.
  1. oldguy
    oldguyMember
    9
    Sep 13, 2012
    Reno, Nevada
    My power outlet quit working and I can't find a fuse or cause. The cigar lighter is okay so I'm rather puzzled. TIA
  2. 7mopar
    7moparWell-Known Member
    1,711
    791
    Dec 21, 2013
    If you have the owners manual ir should tell what fuse to check. Nothing attached to metal any more so it could be a simple ground problem.
  3. oldguy
    oldguyMember
    9
    Sep 13, 2012
    Reno, Nevada
  4. oldguy
    oldguyMember
    9
    Sep 13, 2012
    Reno, Nevada
    The owners manual doesn't show anything for the power outlet, just the cigar lighter. It's working so they must be on different circuits. Puzzled.
  5. 7mopar
    1,711
    791
    Dec 21, 2013
    The center of the outlet is power. It can be checked with a simple test light or volt meter. Power to ground.. Use an ohm meter to check the ground to any known good ground. At least you will know which side of the port is bad.
  6. 65 sporty
    65 sportyWell-Known Member
    1,502
    796
    Aug 8, 2015
    Marlette, Mi
    I did some google research and other guy's are saying it's on the back of the fuse block with one other fuse.
    Dismiss Notice
