Shorty Thompson
Anyone know the correct way to bleed the brakes ?
If the brakes don't bleed there is an ABS problem. The only solution will be to take it to the dealership and have the ABS reset or replaced.
We have 2 Snapon's and a Matco. I haven't had to use the Matco for this yet, but I have used the Snapon on some in the past. I don't remember if I ever tried it on a Ford Superduty.Must take a darn good scam tool to run the ABS pump. Mine will not do it nor would the local shop big machine do it. The ABS would not let fluid bound and pedal would go hard. We tried with the engine running and off with the same results. I hope the OP has better luck with this.
My Innova will not do it. It would tell what needed to be done but otherwise yes a no go.We have 2 Snapon's and a Matco. I haven't had to use the Matco for this yet, but I have used the Snapon on some in the past. I don't remember if I ever tried it on a Ford Superduty.
