52 dodge one ton
Would not even know where to start. Unless there is something out there after market for one of the other brands. Anything from Ram today doesn't even have the same bolt pattern. Guess you could always buy a newer housing with disk brakes and have it cut down to fit. Might even be the cheapest option if you know a machine shop that will mess with it.
That's a straight axle under there, that complicates things. Perhaps look at some RV from the 70's/80's? They should all have disc by then but they may be way bigger than what you need or that will fit?
He will have to get 94 or newer to get disk brake's in the back. I have an 86 Dana 70 with drums.
