Results 1 to 5 of 5
Thread: 4sd to nv4500
  1. #1
    Junior Member
    Join Date
    Mar 2012
    st louis, mo
    Posts
    3
    Country
    United States
    Question 4sd to nv4500
    i have a 1979 dodge 2wd dually with a 4sd, granny low. I was told that a nv4500 trans ( out of 94 to 2004 5sd) wood bolt right up. has anyone done this?
  2. #2
    Senior Member bear's Avatar
    Join Date
    Jun 2011
    Mass
    Posts
    380
    Country
    United States
    Default
    I have'nt done this swap yet but I'm gunna be helping someone with one in a short bed 360 79 Warlock . So it is doable but some of the thing's your gunna have to concider are clutch ( hydralic or mechanical ) , drive shaft , shifter location , and the trany cross member and mount . Though's are just the thing's off the top of my head at the moment .
  3. #3
    Junior Member
    Join Date
    Mar 2012
    st louis, mo
    Posts
    3
    Country
    United States
    Default
    Do you know if the 4500 will bolt up to the 4sp bell houseing?
  4. #4
    Join Date
    Jun 2011
    Mass
    Posts
    380
    Country
    United States
    Default
    The 4500 has an intergrated bell houseing and more then likely you'll have to use the hydralic clutch . What we had decided to do with the Warlock was run a Passon Performance A-855 and use the stock bell houseing . But now he decided to go with a big block and a 727 instead . So the 5 speed idea is off for now , or at least untill he get's tierd of the automatic . lol
  5. #5
    Junior Member
    Join Date
    Nov 2012
    Mizoo MT
    Posts
    7
    Country
    United States
    Default
    I hope your truck still has a 360 right? it will have to be a NV4500 from a 3/4 or 1 ton 2wd 360 gasser, bellhousing should bolt right up but it will have the provision for a crank sensor, no biggie. and it should have the external hydraulic clutch assembly with the gigantic saddle looking monster for a release fork. As stated, trans mount and cross member will require some mods, as well as driveshaft length and the yokes. If possible save the flywheel from the donor truck too, since in 79 trucks had the 11 inch clutch, and 94+ used 12 inch setups.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
